How to install Rockbox on an iPod Classic
  1. How to install Rockbox on an iPod Classic, How to install Rockbox on an iPod Classic: step 1, image 1 of 1
    • Connect your iPod in normal mode (iTunes/file transfer).
    • Close iTunes completely if it opens when you plug in your iPod, as iTunes will try to interfere with this process if it is left open.
    • If on Mac. make sure to run Rockbox Installer as a root user.
    • Download the Rockbox EXE file at the link below. Run the Rockbox EXE file and click OK through the dialogues.
    • Download the Rockbox EXE file here
    • Once you are at this screen, click "Show disabled targets" and click OK at the dialogue.
    • Don't be spooked by the dialogue... even if something were to go wrong with this process we can still go back and restore your iPod.
  2. How to install Rockbox on an iPod Classic: step 2, image 1 of 2 How to install Rockbox on an iPod Classic: step 2, image 2 of 2
    • After you have enabled the disabled targets, click the "Autodetect" button and your iPod's model should be highlighted in the menu above.
    • After you have selected your iPod's model, click OK.
  3. How to install Rockbox on an iPod Classic: step 3, image 1 of 2 How to install Rockbox on an iPod Classic: step 3, image 2 of 2
    • For the next steps we will be installing everything but the bootloader. We will deal with the bootloader later on.
    • Check all of the boxes selected in the blue box.
    • After checking all of the boxes that are necessary, click install.
    • Take a sip of your beverage, or a bite of your food while this process is being completed. It should not take very long.
  4. How to install Rockbox on an iPod Classic: step 4, image 1 of 2 How to install Rockbox on an iPod Classic: step 4, image 2 of 2
    • Once the installation of the firmware, themes and games has been completed, it's time for the most challenging part... the bootloader.
    • Check the bootloader checkbox.
    • Click install again.
    • You must follow the on-screen instructions in order for this to work. Pay close attention to the console. Make the window bigger so you can interpret the text easier.
    • When this message appears in the console, press and hold both the MENU and the SELECT button until there is a message in the console telling you to release the buttons.
    • It is important to do this quickly, otherwise the process can fail requiring you to re-do everything in this step.
    • If this process has been successful, you will see that Rockbox has started on your iPod and a success message will appear on the console.
    • One other thing from my experience is that the console may take obnoxiously long to tell you the installation was successful but the iPod is running Rockbox just fine. You should be OK to remove your iPod anyways.
Let me know if you have problems installing Rockbox with this guide in the comments. I will try to attend to every question I see.
28 other people completed this guide.
[deleted]
27,664 Reputation
21 Guides authored
18 Guide Comments
Rockbox failed to install on mine. I followed every step but never got the message to press and hold select and menu for the bootloader. It said it had installed sucessfully but when it booted up I just got error -3. I put it in disc mode and deleted the software but it didn’t put it back to factory settings. Tried to install again but got the same thing except it said bootloader was already installed when I tried the last step. I’m afraid it is now bricked. :(
jdennis61 - Reply
From my experience if you run into trouble like that youll need to detete the MBR (master boot record) then delete all partitions. Next you create a new Fat32 Partition and finally you will Format the Partition also as Fat32 all I use is AOMIE Partition Assistant and its FREE. Then Apple iTunes will detect it soon as you start your ipod and plug in to computer, will be detected as an iPod in recovery mode. From there I think you know the rest from there. I hope that helped even if a little to late for supper. Lol
Ms. Danielle Rae
Danielle Rae Goodman -
Hi,
I am running rockbox release 15e1f592D-170118 on my Ipod Classic 7th gen. Soundwise should I look for a newsest release
also would you know at which frequency and range works the Rockbox ‘‘bass’’ setting
Thanks a lot
Denis
Denis Ménard - Reply
I tried to install Rockbox onto my iPod Classic 160GB, and I got no results , as a matter of fact; I got negative results asuch as I am not able to restore my iPod Classic in iTunes on my Mac, and I can’t listen to any of my music on the device, even though it appears as though my music is still there. Please help 911 because this is one of my favorite Apple devices of all time!
Dennis Porter - Reply
How do i uninstall rockbox and restore my ipid?
Brant Mcgregor - Reply
Past 24 Hours: 82
Past 7 Days: 535
Past 30 Days: 2,261
All Time: 101,389
